This command enables the specified IS-IS router process on the current virtual router.
| area_name | Specifies the name of the IS-IS router process to be enabled. |
Disabled.
The router process has a system ID and area address configured.
At least one associated VLAN interface has IPv4 or IPv6 forwarding enabled.
This command has no effect on router processes that are already enabled.
The following command enables the IS-IS process named areax:
enable isis area areax
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
